rdg Posted October 7, 2008 Share Posted October 7, 2008 (edited) Hi, when compiling stuff with the hdk on opensuse 10.3 64bit I get some message while compiling/linking and later while running the dso. vmuriel suggested that this might be a mix-up in the linker path, but rereading the messages again and again I almost guess I am using the wrong compiler. 1: compilation/linking I am using the default hcustom ./sample_install.sh from a shell that sources the correct houdini_install Making SOP_CliffordAttractor.o and /home/rdg/houdini9.5/dso/SOP_CliffordAttractor.so from SOP_CliffordAttractor.CIn file included from /opt/houdini/toolkit/include/UT/UT_Vector.C:30, from /opt/houdini/toolkit/include/UT/UT_Vector.h:273, from /opt/houdini/toolkit/include/GB/GB_NUBBasis.h:27, from /opt/houdini/toolkit/include/GU/GU_Detail.h:36, from SOP_CliffordAttractor.C:33: /opt/houdini/toolkit/include/VM/VM_Math.h: In static member function Edited October 7, 2008 by rdg Quote Link to comment Share on other sites More sharing options...
rdg Posted October 7, 2008 Author Share Posted October 7, 2008 From http://odforce.net/wiki/index.php/HDKFrequ...uestions#Linux: You must be careful to use the same compiler as the build of Houdini you installed. I guess this answers my questions. Here is a white paper how to install multiple gcc on the same system: http://www.tellurian.com.au/whitepapers/multiplegcc.php Not sure if I am up to this. Quote Link to comment Share on other sites More sharing options...
