QUESTION: Audio controlled Visuals (real time)
Yo, I am about to embark on a voyage of creating some visuals to go with my music. :)
I have already done a test with Houdini and Chops to create an animation that reacts to the music
- http://uk.youtube.com/watch?v=-iFxm5Qapag
I want to do something quite similar to that although I would rather have something work in real time, so It can react straight to ,what is being played
in a dj set, (I
You can use the AudioIn CHOP to pull a snippet of audio into CHOPs, and then use various filters to produce your animation. The trick is to use Time-Slice mode - it's a toggle on some CHOPs that allow them to work in realtime (some CHOPs don't need it because they work the same in realtime and in non-realtime). Before you start the project, you may want to make it easy on yourself and turn on "Enable Time Slice Flag when Creating CHOPs" in Edit->Preferences->Motion And Audio.
To listen to realtime audio, the Audio panel has to be changed from Scrub mode to Realtime mode (Windows->Audio Panel).
In order to cook, you need to be playing forwards. Other than that, it's pretty similar to working in CHOPs without Time Slicing.
wicked thanks
this is definatly a good start!
do you know if its possible to have a recorded input into the input of chops?
as in what is playing live,
so I can play a dj set and it react in time, rather than having to get a sound byte first?
cheers'n =)
