flipping IK problem
ofer
Hi.
After I watched the technical rigging series from 3dbuzz, Im trying to rig my robot again.
So, I'm working on the leg, and Im using a two-bone chain with IK with Constraints. It basically works, but I have a problem that as I move the end affector around, the chains jumps and flips at certain points. It is probably because of the constraints, but I must use these.
The bones are only allowed to rotate around their X axis.
I attached a short movie that shows the problem. What can I do about it?
Thanks.
rigProblem.movFetching info...
