small problem with chops
hi,
I was trying out chops for the first time. I am having a small problem.
The file is very basic. I have a line which is getting deformed using a WAVE chop. In the CHOPS network i am using a wave chop to create a sin wave and a rename chop to rename it to t[y]. Then I am using a CHANNEL SOP to access it and I put in t[y] and P(1) as my values. I am getting the result.
The problem is, the minute I change the wave chop, the line disappears and the CHANNEL sop says it cant find channel "ty". but if I save it and reopen the file it updates with the new values.
What am i doing wrong?
I am attaching the file for reference.
Also another question, If I want to apply this value to PSCALE or any custom attribute I create using attributecreate sop, what would I type in the CHANNEL SOP?
I have never really worked on CHOPS before, so these are really my first experiments, so any help would be appreciated.
with regards
Rohan Dalvi
chops.hipnc
hey man
I see what u mean, its kinda wierd,
oh well :)
I did however try doing something that produces the effect u want,
try taking a look at the file and what seemed to work was just adding a null node just after ur rename CHOP.
this must be a bug,
take a look at the attached files.
attached should be an example of how this works with a null CHOP, and a version called scale, whereby i take the value out of CHOPS and use that in ur pscale attribute (that i added with the point sop)
hope this works.
chops.hipnc
chops2.hipnc
scale.hipnc
:blink:
thanks a lot.
I guess it was a bug. :huh:
Do you think I should inform sidefx about it.
But anyways, it finally got working the way i wanted.
I am actually trying to making some animated charts and graphs using some data from some excel files.
I was reading on the forum that you can save a txt file as a chan file and bring that into CHOPS, so that finally worked properly.
thanks once again for your help.
this software never ceases to amaze me. :)
with regards
Rohan Dalvi
