Slime
pj1138
hi i`m shooting particals up into a peace of geometry which is acting as a collision object. The particles have been copied onto a metaball to give a liquid effect so that the final effect is as if liquid is shooting up into the air and forming the object shape. Hope this makes sence so far. I am having problems making the liquid look like it is dripping (almost a slimy texture)
Hope the image helps. the slime was done quickly in photoshop.
HELP please :(
sorry here is the image
ok, here're my first thoughts:
since you're colliding with another object, you youd birth new, smaller particles at collision time (maybe use a split pop, to split colliding particles), which then fall down. To give it a somewhat viscous look, check out the proximity poop. You could have particles that are close to each other merge to form bigger blobs before they drip.
Ok, bye,
Jens
poop
