ofer Posted November 29, 2008 Share Posted November 29, 2008 Hi! Im working on a digital asset of a procedural model. I use a creep SOP in there, and the shapes fed into this SOP can be changed from the asset level. If they are changed, I need to go inside and click on the Initialize->Fill Path option. I can leave the creep SOP editable,but this is still too clumsy. Is there a way to add a button to the asset that will trigger the Initialize button? Thanks. Quote Link to comment Share on other sites More sharing options...
AdamJ Posted November 29, 2008 Share Posted November 29, 2008 ugh.. I remmember we were dealing with this on some assets last year.. from what I remember the creep fields were promoted up and there was a callback script on the top level button that would initialize them.. opparm -r -C ./creepNode Initialize (initfill) Hi!Im working on a digital asset of a procedural model. I use a creep SOP in there, and the shapes fed into this SOP can be changed from the asset level. If they are changed, I need to go inside and click on the Initialize->Fill Path option. I can leave the creep SOP editable,but this is still too clumsy. Is there a way to add a button to the asset that will trigger the Initialize button? Thanks. Quote Link to comment Share on other sites More sharing options...
ofer Posted November 30, 2008 Author Share Posted November 30, 2008 Thanks a lot. Quote Link to comment Share on other sites More sharing options...
