expression on range
mic
hello!
Is there any opportunity to write some expression to the 'range' parameter (when creating hda, for example)? when i try to enter anything except numbers it flickers red.
if not - can't it be fixed in H10 ? =)
Edited by mic
hmm, the reason of that was only convenience - i created some menu with type of zoom lenses (18-125 mm, 28 - 90 mm etc, which parses from file) and i want to create the locked range for user according these focal lengths. =) so, i think i take your advice and use clamp)
thank you)
I guess you can clamp based on your menu.
Instead of putting the whatsoever_expression_you_use_to_parse_from_file_and_should_go_into_the_range_settings_of_the_parm in the Edit Operator Type Dialog, put it into the clamp ...
