zbhoudini Posted December 27, 2008 Share Posted December 27, 2008 i have a problem with my vex learning,i don't know how to express some certain point's position with vex;for example,there are three points,point1,point2,point3;how to write expression like this:first i use import() to get position from point1,then i want to assign point1'position to point2'position(point2.P=point1.P),how to do this?anyone help me?thank u. Quote Link to comment Share on other sites More sharing options...
hoknamahn Posted December 27, 2008 Share Posted December 27, 2008 (edited) i have a problem with my vex learning,i don't know how to express some certain point's position with vex;for example,there are three points,point1,point2,point3;how to write expression like this:first i use import() to get position from point1,then i want to assign point1'position to point2'position(point2.P=point1.P),how to do this?anyone help me?thank u. In VEX you're working with just one "current" point (implicit model) which VEX engine gives to your code. You can't "say" in your code "Please take that point number 25 and set it's coordinate to {0.0f, 0.0f, 0.0f}". If you need that particular "point number 25" you could say "if current point has a number equal to 25 do something". But even if you can't operate on particular point of geometry directly (you can do that using Python) you still can fetch attributes from "any point" in different ways: 1. One of the forms of import(): int import(string attrib_name, type result&; int input; int pt_num) 2. Using point clouds How your task could be done: ... vector p; // First input is 0, second 1 and so on. Suppose your SOP has two inputs, // first for actual geometry, second for sampling purposes int input = 1; // ptnum is a global variable which gives a number of current point, "ptnum - 1" is a previous point int pt_num = ptnum - 1; import("P", p, input, pt_num); P = p; But also you have to check correctness of pt_num. For point with number 0 you'll get pt_num == -1 which is wrong. Probably it could be Npt - 1. Edited December 27, 2008 by hoknamahn Quote Link to comment Share on other sites More sharing options...
zbhoudini Posted December 28, 2008 Author Share Posted December 28, 2008 In VEX you're working with just one "current" point (implicit model) which VEX engine gives to your code. You can't "say" in your code "Please take that point number 25 and set it's coordinate to {0.0f, 0.0f, 0.0f}". If you need that particular "point number 25" you could say "if current point has a number equal to 25 do something". But even if you can't operate on particular point of geometry directly (you can do that using Python) you still can fetch attributes from "any point" in different ways:1. One of the forms of import(): int import(string attrib_name, type result&; int input; int pt_num) 2. Using point clouds How your task could be done: ... vector p; // First input is 0, second 1 and so on. Suppose your SOP has two inputs, // first for actual geometry, second for sampling purposes int input = 1; // ptnum is a global variable which gives a number of current point, "ptnum - 1" is a previous point int pt_num = ptnum - 1; import("P", p, input, pt_num); P = p; But also you have to check correctness of pt_num. For point with number 0 you'll get pt_num == -1 which is wrong. Probably it could be Npt - 1. thank you hoknamahn! i have a sin() wave curve with 50 points in node's input 2,a grid with 4 rows and 50 columns.what i want to do is ptnum0's position of sin()curve correspond to grid's punum[0-3],curve ptnum1-grid ptnum[4-8]; this is my code,but failed. vector positionfrominput2,current;int i,j; for(i=0;i<50;i++) for(j=4*i;j<4*i+4;j++) { import("P",positionfrominput2,1,i); import("P",current,0,j); current.y=positionfrominput2.y; } Quote Link to comment Share on other sites More sharing options...
hoknamahn Posted December 28, 2008 Share Posted December 28, 2008 Check this example scene. csbyc.hipnc Quote Link to comment Share on other sites More sharing options...
zbhoudini Posted December 29, 2008 Author Share Posted December 29, 2008 i learned a lot from your example. what i can do is to say "thank you very much". Quote Link to comment Share on other sites More sharing options...
