image based modeling for projection / cam projection commonly
hatrick
I try to get into imagebased modeling for projection in houdini....Is there a good workflowtutorial?
I found this http://www.fanux.net/tmp/mbilginer_pr_root/index.html and it was quite helpful but there is no detailed info bout the modeling process...
for example how to setup geometry with 3d trackers as reference. etc... i use syntheyes for tracking and import export works quite good.
Cmi has some tuts for cinema 4d...in R11 there is a new tool called projectionman ... is there something comparable in houdini
I would be greatful for any tip bout this issue
multicam setups .... painting methods etc
thx
  • 3 weeks later...
