sky Posted April 18, 2003 Share Posted April 18, 2003 Hi there When I used stamp copy ($PT) with POP which have Const. Activation, instance copied grid changed at particle's lifetime was over. Maybe $PT was changed when particle's lifetime was over. Is there a way to maintain stamp copied grid although particle's lifetime was over ? Thanks Quote Link to comment Share on other sites More sharing options...
FrankFirsching Posted April 18, 2003 Share Posted April 18, 2003 As far as I understand you, you will be better off using $ID instead of $PT. $PT is the number of the point in the object. This is always a continous range. That means, if a particle in the middle of this list dies, then the point-numbers of all following particles will decrease by one to fill the gap. The $ID is really a unique identification-number of the particle, which doesn't change. Quote Link to comment Share on other sites More sharing options...
sky Posted April 18, 2003 Author Share Posted April 18, 2003 Thanks FrankFirsching It work correctly ! Cheers Quote Link to comment Share on other sites More sharing options...
