Point follow a path without "Path Object"
Netvudu
just if interested here is wrangle solution using the primuv() function and polyframe. From polyframe you get "N" and "up" for a local Rotation Matrix and from the curve itself you get the postion "P" for every u-value (not just limited to the discrete points), since primuv interpolates the values inbetween.
transform_along_curve.hipnc
