LEO-oo- Posted January 21, 2009 Share Posted January 21, 2009 I have a string with a time stamp: time = "00:20:30" # HH:MM:SS How to add 4 seconds to this string? Thanks a lot! Quote Link to comment Share on other sites More sharing options...
rdg Posted January 21, 2009 Share Posted January 21, 2009 I have a string with a time stamp:time = "00:20:30" # HH:MM:SS How to add 4 seconds to this string? Thanks a lot! You probably could do some split() magic and add 4 seconds to the last part. More convient would be to split it and convert completely to seconds and just format the output string. Not sure if the datetime[1] module is very usable for this, but it's worth a look. [1] http://docs.python.org/library/datetime.html Quote Link to comment Share on other sites More sharing options...
eloop Posted January 22, 2009 Share Posted January 22, 2009 Something like this will work. I've broken it up into a function to make it a bit cleaner, and a bit more general. def add_seconds(timestring,n): h,m,s = map(int,timestring.split(":")) ts = s + 60*m + 60*60*h + n h,ts = divmod(ts,60*60) m,s = divmod(ts,60) return "%0.2d:%0.2d:%0.2d" % (h%24,m,s) time = "00:20:30" # HH:MM:SS newtime = add_seconds(time,4) print time,newtime -Drew I have a string with a time stamp:time = "00:20:30" # HH:MM:SS How to add 4 seconds to this string? Thanks a lot! Quote Link to comment Share on other sites More sharing options...
LEO-oo- Posted January 22, 2009 Author Share Posted January 22, 2009 @rdg Ich war auch schon auf dieser Seite @eloop It works perfect - thanks a lot!!! :) Quote Link to comment Share on other sites More sharing options...
rdg Posted January 22, 2009 Share Posted January 22, 2009 @rdgIch war auch schon auf dieser Seite yep Drew's way is more applicable here. Quote Link to comment Share on other sites More sharing options...
