rohandalvi Posted January 27, 2009 Share Posted January 27, 2009 (edited) hi, This is a simple question, but I cant figure out the expression. How can I vary the activation time for an effect or a force? Lets say I want it to start between frame 20 and 50 based on rand($ID) what would be the expression? Or even if I can bring particles into a group over a period of time, I guess even that would work. Still what would be the expression? with regards Rohan Dalvi Edited January 27, 2009 by rohandalvi Quote Link to comment Share on other sites More sharing options...
rdg Posted January 27, 2009 Share Posted January 27, 2009 (edited) rohandalvi said: How can I vary the activation time for an effect or a force?Lets say I want it to start between frame 20 and 50 based on rand($ID) what would be the expression? something like: if($F > int(fit01(rand($ID), 20, 50)), 1, 0) * rand returns a 0..1 value * fit01 rescales this value to the new min max * int makes an integer - maybe unnecessary if you are dealing with floating frame numbers * if(cond, then, else) sets the activation to 1 if condition is true. untested. Edited January 27, 2009 by rdg Quote Link to comment Share on other sites More sharing options...
rdg Posted January 27, 2009 Share Posted January 27, 2009 thinking about it: Activation might not be controllable on a per particle basis. In this case keep the force activated and animate the strength based on the expression ... Quote Link to comment Share on other sites More sharing options...
rdg Posted January 27, 2009 Share Posted January 27, 2009 rohandalvi said: Or even if I can bring particles into a group over a period of time, I guess even that would work. Still what would be the expression? Indeed for WindPOP this is the most reliable approach. setup_activate_force_at_random_frame.hipncFetching info... eof Quote Link to comment Share on other sites More sharing options...
rohandalvi Posted January 27, 2009 Author Share Posted January 27, 2009 (edited) thanks a lot RDG, thats exactly what I wanted. I am just not very good with expressions, so even though i can understand the logic of what I need to do, I can"t always get the expressions right. so thanks again. Edited January 27, 2009 by rohandalvi Quote Link to comment Share on other sites More sharing options...
