random texture assignment
artzor
hi guys,
i'm doing a little project for a friend and need some help...
i want to scatter points on a surface and then use a copy sop to get a bunch of random planes, and i want them to have different textures
so i'm thinking somehow getting rand($PT) from the scattered points into the material to drive a switch operator which just has different textures coming into it...
but i can't get it to work :(
thanks!
thanks AndrewVK, but i do really want to learn how to do this myself :)
-edit -
haha, figured it out, you can just stamp a rand($PT)
and then in a material operater add a local overide with the stamp as an integer value...
houdini is niiiiicccceee!!!
Edited by artzor
working great :)
which leads me to the next challenge, how this applies to instanced points instead of scattered points...???
Turn on "Use Template Point Attribute" (Copy Sop -> Attribute Tab )
Put this string: shop_materialpath material_override
to "To Primitive" field
thanks again AndrewVK :)
my last question on this subject, my shader setup is quite tedious now...
i've stamped a rand($PT) and put that through to local overides in the material op.
then i'm using the local overide parameter to flip a switch node which has lots of strings(images) going into it...
is there a way to get the local overide parameter into one string,
so if i have images 0.jpg, 1.jpg 2.jpg etc i can just go images\`switcher`.jpg
make sense?
edit : it works with paramters like `$F` in the string name but i can't seem to get the value from the local overide (which came from copy stamping)
Edited by artzor
  • 5 years later...
