Sayden Posted February 6, 2009 Share Posted February 6, 2009 Hi guys I want to make a copy of a grid with X objects above. For example 20 grid with a 4 objects at first, 13 objects at second, 5 objects at third, etc. What expression should I put in the Copy SOP? and Where should I put the stamp expression? Sorry for my english, I try to do my best I can Quote Link to comment Share on other sites More sharing options...
apatrick Posted February 6, 2009 Share Posted February 6, 2009 If I understand what you want to do properly you need two copy sops, one to create the stack the other to copy it to the grid, the second copy sop stamps the number of copies on the first - is the attached example what you need? Sayden said: Hi guysI want to make a copy of a grid with X objects above. For example 20 grid with a 4 objects at first, 13 objects at second, 5 objects at third, etc. What expression should I put in the Copy SOP? and Where should I put the stamp expression? Sorry for my english, I try to do my best I can stackup.hipncFetching info... Quote Link to comment Share on other sites More sharing options...
Sayden Posted February 6, 2009 Author Share Posted February 6, 2009 Wow, it was pretty simple, a stamp in the copy attribute But that was not exactly what I am looking for because it is not like a stack. I need to make nCopies from Box for each grid (not for each point grid). That Quote Link to comment Share on other sites More sharing options...
old school Posted February 6, 2009 Share Posted February 6, 2009 Just need to use a group SOP between the grid and the Copy SOP and use stamping to populate the group. In the Copy SOP's template group field, put the name of the group in there. Or use a delete SOP between the two deleting points in expression mode using Copy SOP stamping. That is if I understand what you want... Quote Link to comment Share on other sites More sharing options...
Sayden Posted February 7, 2009 Author Share Posted February 7, 2009 (edited) That's was my first idea but it didn't work. I've just try it again and it seems that it is working (last time I try to group by expression instead of pattern) but I am not sure if there is a better way. I have attached the file: It's a simple procedural build that I will convert in a procedural city, I will upload it in a few days Thx! gridBoxes.hipncFetching info... Edited February 7, 2009 by Sayden Quote Link to comment Share on other sites More sharing options...
