Unwrap render / baking shows artifacts
Hello all,
i recently investigated in rendering lightmaps in Houdini. I liked the mantra -u option, but, after some testing, came across some limitations:
When the surface is being deformed (I am not using displacement) to a certain extent, black spots become visible, similiar to dicing errors in normal renders. However, changing the dicing option in the geometry has no effect. If I render everything with flat geometry there are no errors. I have vertex UV attributes with no overlapping UVs.
I have attached an example hip file as I have totally ran out of ideas how to fix this.
You can disable the mountain SOPs and the render should be without artifacts. I suggest this could have something to do with the camera, but I do not know.
I would be very greatful if somebody could shed some light on this - I am clearly doing something wrong here.
Thanks
Johann
bake_lighting.hipnc
Edited by jwoelper
To quote myself, I found out that these artifacts are dependent on the current perspective camera.
If I look at the scene loosely from the top (in the direction of the negative y-axis) the artifacts disappear. If I tilt the view, they appear again. Should'nt the render be independent of the scene camera? At least, I did specify /obj/cam1 as camera in the mantra output node...
Could this be a bug?
(I am still under 9.1.244 here, will test this with 9.5.x)
Cheers
Johann
Hello all,
Thanks
Johann
Cheers
Johann
I think the issue might be that in your shader, there's a "frontface()" call. This flips the normal so that it's pointing toward the camera.
Which means that the "front" of the surface will be shaded (not the back) - the part of the surface that's visible to the camera.
When unwrapping, the frontface() function can "flip" the normal to be pointing the wrong way.
So, as the position/orientation/view of the camera changes, the black patches would also change (since different parts would be front-facing).
I think the easiest solution would be to change the shader so that the frontface call is eliminated.
