vops displacement question
Hey guys,
I have a piece of geometry that has a custom attribute mapped to its surface. I would like to
take that attribute into a vops displacement shop and create an displacement based on the value
the custom attribute holds. Is this possible? If so, I am not sure how to pass that information
into vops. I thought that maybe I could use a parameter node and pass it through that but
that does not seem to work.
Any ideas?
Thanks a million,
walter
if you create a parameter named exactly the same in VEX context then you can probably use that parameter to drive a certain factor.
i.e if I want to import uvs into VEX, i'll put in a parameter node and name it uv and set the type to vector.
i have not yet dealt displacement maps as i'm still scratching the surface.. :)
hope this gets you some idea.
