Help: VS2008 / hcustom
People im loosing mu nervs here,
can any1 write down how to setup VS2008 so i can compile stupid sample???
hcustom doesnt work, or im stupid, when i try to compile something im gettting error
SOP_Star.C
Unknown compiler version - please run the configure tests and report the results
so would be nice if some1 could make help for us stupid guys
cheers and thx
  • 2 months later...
h10 is good to go for vc8
i was able to compile the maxwell plugin for 10 today, however...................
first setup according to the docs mentioned above and ensure that cl.exe runs from a houdini shell
from that shell, navigate to %HFS%/toolkit/samples/SOP
you will need to run
hcustom -e SOP_star.C >> output.bat
then edit the output.bat file to remove the lines up to the last long one that starts:
C:\Program Files\....\cl .......................
edit the C:Program files\.........cl
to just read cl or cl.exe
then remove the UT_DSO_VERSION = longhexnumbers line as it will keep the plugin from compiling
this is a bug in hcustom for windows 64bit and currently this is the only workaround i have found to work, not sure if there is the same issue with the 32bit version.
i sent the bug into support but have not heard a response for a fix yet
good luck
