peterr Posted February 26, 2009 Share Posted February 26, 2009 Okay, I'm having an old man moment (seem to be getting longer), ah where was I Right, I'm in Singapore at the moment and trying to answer a question about particle fluids. We know that particle fluids need to settle and you can write out the simdata to disk. What I can't sort out is how to bring the simdata back in and start at the point where the particle fluid has settled. Who can help? Alvin where are you when I need you... PeterR Quote Link to comment Share on other sites More sharing options...
wolf_cub_one Posted February 27, 2009 Share Posted February 27, 2009 Sorry, don't have Houdini in front of me right now but just read in the data in the simulation tab using the frame you want to start at. HTH Quote Link to comment Share on other sites More sharing options...
SpencerL Posted February 27, 2009 Share Posted February 27, 2009 (edited) Okay, I'm having an old man moment (seem to be getting longer), ah where was IRight, I'm in Singapore at the moment and trying to answer a question about particle fluids. We know that particle fluids need to settle and you can write out the simdata to disk. What I can't sort out is how to bring the simdata back in and start at the point where the particle fluid has settled. Who can help? Alvin where are you when I need you... PeterR On your Particle Fluid Object > Initial Data Tab, switch the input type parameter from "Surface SOP" to "File" Edited February 27, 2009 by SpencerL Quote Link to comment Share on other sites More sharing options...
