tayga Posted February 27, 2009 Share Posted February 27, 2009 i have an animation cycle baked in to bgeo files. How can I cycle throw files when i read them? Thanks Quote Link to comment Share on other sites More sharing options...
stevenong Posted February 28, 2009 Share Posted February 28, 2009 Hi, You can append a Time Warp SOP to the File SOP, set the Input & Output Ranges to match the length of the cycle & set the Pre & Post Extend parameters to Cycle. Hope the above helps! Cheers! steven Quote Link to comment Share on other sites More sharing options...
tayga Posted February 28, 2009 Author Share Posted February 28, 2009 Hi,You can append a Time Warp SOP to the File SOP, set the Input & Output Ranges to match the length of the cycle & set the Pre & Post Extend parameters to Cycle. Hope the above helps! Cheers! steven it is exactly what i need !!!! Thanks a lot !!! 1 Quote Link to comment Share on other sites More sharing options...
