Expression for a random point selection over time
afx
Basically I have a group of points with something like this as its point selection (4, 5 ,6 12, 16, 20) I want to randomly pick one of these point numbers and over time pick another one of these numbers.
example.
frame (1) = point selection (5)
frame (2) = point selection (12)
frame (3) = point selection (4).......
its getting late, and in zombie mode if I dont make sense I can clarify
Looks like that doesn't seem to do the trick
Let me know if you guys think I should be doing this differently
I have a Box node
I then selected a group of points and asigned them to a group node
I now want to individually select one of these points in the group node and translate it, but I over time want to change this selection so that the translation moves from point to point within my selection group
I might be setting this up wrong any suggestions??
If this is really what you want then it might be easy or hard to find a solution depending on what you plan.
After reading it again it sounds like you want:
Have a selection of point on your box
Apply a montainSOP to this group
Or: Add a custom pointSOP expression or even VOPSOP to this group
You can also us the combine tab of the groupSOP to create a subset of your first group.
