artzor Posted March 13, 2009 Share Posted March 13, 2009 besides verbose level, is there a way to get some useful stats while rendering? like poly count... sampling settings, maybe custom settings like number of lights and then somehow store this with the frame in MPlay, so that when i'm flicking through renders and comparing the images i can compare vital settings as well? Quote Link to comment Share on other sites More sharing options...
rdg Posted March 13, 2009 Share Posted March 13, 2009 besides verbose level, is there a way to get some useful stats while rendering?like poly count... sampling settings, maybe custom settings like number of lights and then somehow store this with the frame in MPlay, so that when i'm flicking through renders and comparing the images i can compare vital settings as well? I'd go for a pre-frame script that writes a text file. You could even monkey-path IFD.py to save this information while generating the IFD. As for the MPLAY: Mplay supports adding comments to images, not sure if this could be used to retrieve this information. Quote Link to comment Share on other sites More sharing options...
