bareja Posted March 16, 2009 Share Posted March 16, 2009 Hi i have a question about name and delete SOP operator. I know that name operator creates attribute, then i can transform points using this attribute ex: @rvort==1, but how to delete points uisng attribute value ? It works when i use transform sop and others, but doesn't when use delete sop. Please help, Cheers Scene file to better explain: delete.hip Quote Link to comment Share on other sites More sharing options...
mic Posted March 16, 2009 Share Posted March 16, 2009 Hi i have a question about name and delete SOP operator. I know that name operator creates attribute, then i can transform points using this attribute ex: @rvort==1, but how to delete points uisng attribute value ? It works when i use transform sop and others, but doesn't when use delete sop.Please help, Cheers Scene file to better explain: delete.hip ha-ha, and do you know that everything works in your example if you use Blast SOP?)) Quote Link to comment Share on other sites More sharing options...
Guest Swann Posted March 16, 2009 Share Posted March 16, 2009 (edited) Hey bareja, Switch deleteSOP into expression and place point(opinputpath(".",0), $PT, "lvort", 0) into slot. This is attribute so it can't be accesed by just placing into group name. Or maybe you found some mystique way to acces it with help of @ sign ?! Where did you get it ? I see usage of this for the first time. pozdrawiam Edited March 16, 2009 by SWANN Quote Link to comment Share on other sites More sharing options...
bareja Posted March 16, 2009 Author Share Posted March 16, 2009 Hey bareja,Switch deleteSOP into expression and place point(opinputpath(".",0), $PT, "lvort", 0) into slot. This is attribute so it can't be accesed by just placing into group name. Or maybe you found some mystique way to acces it with help of @ sign ?! Where did you get it ? I see usage of this for the first time. pozdrawiam Thanks for explain SWANN, I've thoguht if in Pattern type "*", operator will delete all points where attribute lvort==1, thanks again. Check documentation of Name SOP operator: This is very similar to groups: using @name=foo is similar to creating a group foo and refering to it using @foo. However, name attributes have two differences from groups: * Names are more efficient than groups. For example, you can assign different names to hundreds or thousands of individual faces, while creating hundreds of groups, each with a single member, would be problematic. * Names enforce the constraint that each primitive can only have one name value at a time (that is, a primitive can Quote Link to comment Share on other sites More sharing options...
