NoobQuestion: Materialising RippleSolverOutcome?
rodpacker
I am almost embarrassed to ask, but I can't seem to figure it out.
I thought I knew how to use dopImports with particle and volumetric fluids, however I cannot figure out how to get them to work with the ripple solver. Or is there another workaround needed for this.
Could somebody please point me in the right direction?
Highly appreciated
BTW sorry for posting it here and at the SideFX forum, just need to get it done and haven't got much response there yet.
cheers
rodpacker
Off the top of my head, you can use an Object Merge SOP and do the following:
/obj/name_of_dopnet:ripple_object_name/Geometry
If you create a Geometry Object & use the shelf to make it a RBD Object, you should get the correct syntax in the DOP Import SOP.
Good luck!
Cheers!
steven
PS If this works, please post over at SESI & direct them here.
