expressions for coloring particles
Thalie
Dear all!!
I'm trying to get an expression in order to color randomly the particles in light brown, dark brown, very dark brown and a little bordeaux tints!
In the shader, I was trying to guess what kind of rand($PT) expression could work, but couldn't find any correct one!
to this picture, I would like to give a feeling of sand! what would be your advice!
Tx all
Hello.
Just quick out of my heard!!!
I think its possible to pipe your particles through a VOPSOP. Inside there you can create a RGB to HSV conversion and
then make a random on the V (value).
Remember to make a HSV to RGB before piping it back to your globals.
Hope it helps
Erik
duckling
Edited by Ezz
Just to give you another solution, you could append to your particles a color node, inside your pop network, then inside it choose ramp, set your colors and add to the lookup value the expression rand($ID)....
Better to do the lookup with a vop sop after the particle network - outside of the particle network - that way if you want to change the color you don't have to resimulate the particles.
