cspears2002 Posted April 2, 2009 Share Posted April 2, 2009 I'm animating panels in a billboard. I have pumped the data from the animated first row of panels into a CHOP network with the ultimate goal of applying lag to it with a Lag CHOP. My problem is I don't know how to get the data out. From what I can see, one would normally use the Channel SOP, but that only works on points. I'm animating primitives. Any hints? chris_sign_v03_alt_animate_keyframe_chops.hipnc Quote Link to comment Share on other sites More sharing options...
petz Posted April 2, 2009 Share Posted April 2, 2009 you can use an export-chop to override your rotation in sops. file is attached petz channel_export.hipnc Quote Link to comment Share on other sites More sharing options...
