Acces the string attribute
kubabuk
Hi all,
I can't overcome this problem. How do I access string attribute stored in a point?
Help says strings are added as index attributes, and indeed I am getting various integer values but how can get a string itself?
Thanks.
kuba
Hi all,
Thanks.
kuba
Use the points() expression.
/ -> exhelp points
string points (string surface_node, float point_number, string attribute)
		EXAMPLES
		  | points("/obj/geo1/facet1", 3, "instance")
		  Returns the string associated with the string attribute "instance"
		  for point 3 in the facet1 surface node in geo1.
		REPLACED BY
			- hou.Geometry
			- hou.Point
