xoctan657 Posted April 12, 2009 Share Posted April 12, 2009 Hi i can't drag the vcc application into my command line in houdini and i can't also drag any file into it so any body have this problem or not , i use vista and houdini 9.5 so are there any answer i have see that the vcc it draged into command line and the file also and it is very easy but in my case i must write the path evry time i want to use vcc application thank for all Quote Link to comment Share on other sites More sharing options...
xoctan657 Posted April 14, 2009 Author Share Posted April 14, 2009 t is very long to me to write the full bath to vcc evry time i want to convert the .vfl to .otl file so what is the fast way to do that any answer Quote Link to comment Share on other sites More sharing options...
stevenong Posted April 14, 2009 Share Posted April 14, 2009 You can use the Command Line Tools (Start > Programs > Side Effects Software > Houdni 9.5.xxx > Command Line Tools) which is a Command Prompt with the executable path set correctly for Houdini. Now, you just have to cd to the correct directory and type vcc -l output.otl input.vfl Hope the above helps! Cheers! steven Quote Link to comment Share on other sites More sharing options...
xoctan657 Posted April 14, 2009 Author Share Posted April 14, 2009 (edited) thanks this is very help but i want to know why i can't to drag the input file -for example- in the commend line and i had see tutorial and in it the instructor drag the the file into the commad line and the path come fast in the command line and no need to write all the path by hands(this is very long) so when i want to do the same the command line don't take any file in it . maybe that just in vista. Edited April 14, 2009 by xoctan657 Quote Link to comment Share on other sites More sharing options...
xoctan657 Posted April 14, 2009 Author Share Posted April 14, 2009 and another Q : if i have copy the path for my input file can i past it in the command line or i must type it letter by letter. Quote Link to comment Share on other sites More sharing options...
stevenong Posted April 14, 2009 Share Posted April 14, 2009 I'm not sure if Vista's command prompt is the same as XP's but I can drop a file into it & also paste with a RMB click. For pasting, you can edit the Properties of the Command Prompt by right clicking on the title bar > Properties, turn on "QuickEdit Mode and Insert Mode", click OK and select "Modify shortcut that started this window". If the above doesn't work, I suggest you google for answers through Vista related forums. Cheers! steven Quote Link to comment Share on other sites More sharing options...
xoctan657 Posted April 15, 2009 Author Share Posted April 15, 2009 (edited) thanks very much Edited April 15, 2009 by xoctan657 Quote Link to comment Share on other sites More sharing options...
xoctan657 Posted April 15, 2009 Author Share Posted April 15, 2009 (edited) in vista don't work Edited April 15, 2009 by xoctan657 Quote Link to comment Share on other sites More sharing options...
