jacys Posted April 21, 2009 Share Posted April 21, 2009 (edited) Layers: http://www.vimeo.com/4367022 http://www.vimeo.com/4366998 --- Final: http://www.vimeo.com/4366968 Edited April 28, 2009 by jacys Quote Link to comment Share on other sites More sharing options...
stevenong Posted April 21, 2009 Share Posted April 21, 2009 Hi jacys, It looks pretty good but there's a pop at the end. Can you post a flipbook version of just the particles so we can take a look? Can you also increase the shadow density a bit more? I expect the shading to have a bit more contrast from the sun. I hope with the increase in shadow density we'll get a bit more detail. Keep it up! Cheers! steven Quote Link to comment Share on other sites More sharing options...
jacys Posted April 21, 2009 Author Share Posted April 21, 2009 Hi jacys,It looks pretty good but there's a pop at the end. Can you post a flipbook version of just the particles so we can take a look? Can you also increase the shadow density a bit more? I expect the shading to have a bit more contrast from the sun. I hope with the increase in shadow density we'll get a bit more detail. Keep it up! Cheers! steven Actually, I only know how to render with mantra. how to play blast its screen? I'll post a flipbook version of just the particles if you tell me how to do. thanks for advice. Quote Link to comment Share on other sites More sharing options...
stevenong Posted April 21, 2009 Share Posted April 21, 2009 Hi jacys, Make sure you're happy with the display of the particles & geometry and in the bottom left of the viewport, there are two icons. The top icon is for generating flipbooks and the other is for rendering with a ROP. Click on the Flipbook icon, set up the frame range if you need to and click Accept. Here's the Flipbook help page. Also, I highly recommend you go through the Houdini basics. You can either go to the Help Documentation at SESI's site or go to Help menu > Houdini Help when you have Houdini opened. Check out the Basics link to get you started and also this Learning Roadmap page. Cheers! steven Quote Link to comment Share on other sites More sharing options...
jacys Posted April 21, 2009 Author Share Posted April 21, 2009 (edited) Hi jacys,Make sure you're happy with the display of the particles & geometry and in the bottom left of the viewport, there are two icons. The top icon is for generating flipbooks and the other is for rendering with a ROP. Click on the Flipbook icon, set up the frame range if you need to and click Accept. Here's the Flipbook help page. Also, I highly recommend you go through the Houdini basics. You can either go to the Help Documentation at SESI's site or go to Help menu > Houdini Help when you have Houdini opened. Check out the Basics link to get you started and also this Learning Roadmap page. Cheers! steven Thanks, check them out. I made three different layers for this scene, two particle's layers by houdini, last one are maya fluid. maya fluid is easy for me, but H10 have new one I interested. Pyrofx. Edited April 25, 2009 by jacys Quote Link to comment Share on other sites More sharing options...
jacys Posted April 21, 2009 Author Share Posted April 21, 2009 Thanks, check them out.I made three different layers for this scene, two particle's layers by houdini, last one are maya fluid. maya fluid is easy for me, but H10 have new one I interested. Pyrofx. http://www.vimeo.com/4255938 http://www.vimeo.com/4255988 mirror here. Quote Link to comment Share on other sites More sharing options...
jacys Posted April 21, 2009 Author Share Posted April 21, 2009 http://www.vimeo.com/4255938http://www.vimeo.com/4255988 mirror here. http://forums.odforce.net/index.php?showto...l=sand&st=0 this topic have a good idea I wanna add. but I am not sure how to make particles collision self? or they were replaced by some small objects? Are these two different way all could make it happen? I tried to make something like it in my project, but I can not make them be influenced by forces, such as wind. If I use particle and replaced by an object, then I notice their edges never collision each other. If I use DOPs and make an object creates objects by expression in "creation frame", such as " if($FF%10==0,$FF,0) ". They just have a great collision but no force can influence themselves. They run like a robot. How come ? and what should I do? Quote Link to comment Share on other sites More sharing options...
jacys Posted April 24, 2009 Author Share Posted April 24, 2009 http://www.vimeo.com/4310449 final version of final versions, Quote Link to comment Share on other sites More sharing options...
Zanozza Posted April 27, 2009 Share Posted April 27, 2009 good joke, jacys: "Sorry, "SandDuneFx-FinalFinalFinal" was deleted at 9:03:08 Fri Apr 24, 2009. We have no more information about it on our mainframe or elsewhere." Quote Link to comment Share on other sites More sharing options...
jacys Posted April 27, 2009 Author Share Posted April 27, 2009 (edited) good joke, jacys:"Sorry, "SandDuneFx-FinalFinalFinal" was deleted at 9:03:08 Fri Apr 24, 2009. We have no more information about it on our mainframe or elsewhere." Sorry, some rights problem need to fix first. I will show another version soon. --- Yup, I have fixed it already. Sorry about that joke, please forget that. Layers: http://www.vimeo.com/4367022 http://www.vimeo.com/4366998 --- Final: http://www.vimeo.com/4366968 Edited April 28, 2009 by jacys Quote Link to comment Share on other sites More sharing options...
borisb2 Posted May 18, 2009 Share Posted May 18, 2009 (edited) looks great !! How did you animate the particles to crawl over the ground ?.. and how did you setup the fluids-layer in maya (I Edited May 18, 2009 by borisb2 Quote Link to comment Share on other sites More sharing options...
jacys Posted May 20, 2009 Author Share Posted May 20, 2009 looks great !!How did you animate the particles to crawl over the ground ?.. and how did you setup the fluids-layer in maya (I Quote Link to comment Share on other sites More sharing options...
