Attenuation
Ezz
Hi all.
This might be a total noob-question, but I have searched a bit with no luck.
In Maya you can have attenuation on forces. How can a achieve that in Houdini in POP`s
Thanks
Erik
Edited by Ezz
You mean like Drag? (Drag POP)
No not really.
Attenuation like in Maya is when a force has a fallof of strenght given by a distance/radius .
Im sure its achieveable with a VOPPOP with som vectormagic :-)
I was just wondering if there is a easy way to do this.
Thanks
Erik
No not really.
Thanks
Erik
Oh like Attractors/Repulsors? You can use Metaballs as fields.
The Fan Force DOP has attenuation, I believe.
Hi thanks for your response.
The fanPOP sure have some attenuation on its force. But only having
noise and not a direction is not possible ( AFAIK)
I can easily create a group(bounding) to controle wich particles I want to be affected
by a given force but there is no way to have attenuation on it.
I think Ill digg in to VOPS
Thanks again
Erik
