Help needed in getting this to work in houdini?
Hi guys,
Another new issue here.
I have this concept and I need to make it work in Houdini, so maybe somebody can give me some pointers.
I have an animated null, a particle instanced with a box in the scene.
when the null move to a certain distance within the box, the box gets attracted and move to the position of the null.
So the concept in programming would be like:
distance between null.tx & particle1.tx = distTX
if (distTX < 10),
particle1.tx move to null.tx
How do I set this up in Houdini?
i have not done much scripting in H before but I have done mel and python in maya.
Thanks for any help in advance.
cheers,
Ray
hey Ray.
You can create an attribute on your particles that calculate the distance of your particles to the null. You can use the expression: distance(float1a,float2a,float3a,float1b,float2b,float3b) a is the particles xyz-position and b is the nulls position. then you can put all the particles that have a greater distance of 10 into a group.
http://www.sidefx.com/index.php?option=com...&Itemid=305
check theese tutorials out and you will have good understanding of how expression works in Houdini.
Hope it helped a bit.
Erik
duckling
hey Ray.
Erik
duckling
Thanks alot! They helped! :)
regards,
-Ray
