Mantra not loading COP reference as texture
Guest YoBeardMaestro
The odForce wiki indicates that COP images can be referred to in shading texture parameters:
http://odforce.net/wiki/index.php/Frequent...VEX_operator.3F
I've attached an example file that demonstrates that, whilst the op: syntax will happily reference the COP image and display it in the viewport, mantra cannot load it. What's going on? Is this a bug?
YBM.
CopRefTest.hipnc
YBM.
Hi there.
It appears that you have a path issue,
Here you have a manually added path , I think that the structure that you are using is not working , By default it is looking in the HOME of the houdini installation and maybe your hip is not in that folder,
Mangi
