sanostol Posted May 19, 2009 Share Posted May 19, 2009 (edited) can I wedge to flipbook, i want to capture different simulation settings Martin Edited May 19, 2009 by sanostol Quote Link to comment Share on other sites More sharing options...
stevenong Posted May 19, 2009 Share Posted May 19, 2009 Hi Martin, Of course. I do that all the time. You need to create new sequences in mplay and the button is third from the top right, beside the "Cancel" button or Render menu > New Sequence. I think this tutorial will give you more information. I love mplay because you can view sequences side by side and more. Go to View menu > Layout > 2 Columns and click in each view to set the sequence from the Image menu or RMB and select it from the bottom. Have fun! Cheers! steven Quote Link to comment Share on other sites More sharing options...
ranxerox Posted May 19, 2009 Share Posted May 19, 2009 I think he means actually using the wedge rop to generate multiple flipbooks with different settings. To do this I think you might need a flipbook rop. I did a cursory search for mplay rop and flipbook rop and couldn't find one. I guess you could make a scripted node which takes an output filename parameter to run the necessary commands to create a flipbook and put your $WEDGE variable in there. Just thinking outloud, not really sure how to do it. -ranxx Hi Martin,Of course. I do that all the time. You need to create new sequences in mplay and the button is third from the top right, beside the "Cancel" button or Render menu > New Sequence. I think this tutorial will give you more information. I love mplay because you can view sequences side by side and more. Go to View menu > Layout > 2 Columns and click in each view to set the sequence from the Image menu or RMB and select it from the bottom. Have fun! Cheers! steven Quote Link to comment Share on other sites More sharing options...
stevenong Posted May 19, 2009 Share Posted May 19, 2009 Doh! I didn't link "wedge" to the Wedge ROP. What ranxerox said is correct. You can create a Wedge Flipbook Digital Asset ROP using the viewwrite command. Do "help viewwrite" in the textport for more info. Cheers! steven Quote Link to comment Share on other sites More sharing options...
