force manual update on file open with mac or winxp
HI,
how do you open a file with a manual update from the gui in osx or winxp? On linux, if I have a troublesome file opening
it with houdini -n filepath does the trick.
I tried opening a session, changing update to manual and then loading the file. However the new file's "automatic" update overrides the previous setting.
thanks
Tom
Hey Tom,
There's always the shell in both OS X & XP. For OS X, there's the Houdini Shell.terminal in the Houdini Application folder and XP has the Command Line Tools shell in Start > Programs > Side Effects Software > Houdini x.x.xxx.
Cheers!
steven
