Collision between smoke and keyframed-object
it should work with keyframed static RBD perfectly fine
just make sure you are animating the object at object level
if you are animating at sop level, you need to check Use Deforming Geometry on RBD object
you can use attractor POP for localised effect
to make it work you will need to specify path to a SOP which contains force attributes
this is usually a metaball SOP followed by Force SOP which has the parameters set according your needs
since it is based on metaballs it is attenuated by default
(if you are working in DOP context you can use Magnet Force DOP with similar usage)
