Ezz Posted May 26, 2009 Share Posted May 26, 2009 (edited) Hi Folks. I need a little help. Im trying to figure out how to map the ConeAngle-value in the raytracing option for the prebuildt glasshader with a texture. I want to control where the glossiness on an objects surface is. I did some initial test where i tried to plug a texturenode into the anglevalue, but it did not have any affect. Any help or hints would be much appriciated. Cheers Erik Edited May 26, 2009 by Ezz Quote Link to comment Share on other sites More sharing options...
jason_slab Posted May 26, 2009 Share Posted May 26, 2009 hey try this file i plugged in a luminance from the texture to the cone angle! jason blur_refl.hipFetching info... Quote Link to comment Share on other sites More sharing options...
Ezz Posted May 26, 2009 Author Share Posted May 26, 2009 (edited) Hi Jason. thanks a lot man. Ill have a look! Cheers Erik Edited May 26, 2009 by Ezz Quote Link to comment Share on other sites More sharing options...
Mario Marengo Posted May 26, 2009 Share Posted May 26, 2009 I haven't looked at the example, but just in case, I thought I'd mention that this is a half angle whose units are in *radians*. Meaning that if you choose to use a texture map's luminance to steer "glossiness", and that luminance had a [lum_min, lum_max] range, and you wanted the cone angle to end up with a [0, 20] degree range, then you'd use something like: fit(luminance(texmap_rgb), lum_min, lum_max, 0, radians(10)); as the value to feed to the cone angle input. P.S: I'm fairly certain the half-angle property extends to the bsdf functions as well (used internally to generate the 'F' output of the Trace VOP), though I'd suggest double-checking that to make sure. P.P.S: I just took a peek and noticed the Trace VOP does the degree-to-radian conversion internally, so disregard the radians bit. Quote Link to comment Share on other sites More sharing options...
jason_slab Posted May 26, 2009 Share Posted May 26, 2009 ahh cool, mine is just a straight forward plug luminance in and render, no real thought about the cone angle... jason Quote Link to comment Share on other sites More sharing options...
Ezz Posted May 26, 2009 Author Share Posted May 26, 2009 (edited) Hi Jason and Mario. Thanks for your responses. Jason your example helped me a lot - Thanks. Furthermore you actually helped me understand how to adjust the environmentmap to control the location af the relection/refraction with a null.....Houdini is so..so...Great yet so overwhelming :-) some times I think my head is gonna explode.... :-) Erik Edited May 26, 2009 by Ezz Quote Link to comment Share on other sites More sharing options...
