hatrick Posted May 28, 2009 Share Posted May 28, 2009 id like to convert a subdivided polygon into a nurbs surface... the interpolation behaves somehow strage with the convertsop... is there a similar way to maya ? thx Quote Link to comment Share on other sites More sharing options...
sibarrick Posted May 28, 2009 Share Posted May 28, 2009 I would say not, unless you roll your own. The convert sop can only convert back to nurbs if the polygons form a regular mesh/grid arrangement, even then you might need to convert to a mesh first and then nurbs, either way anything other than a trivial subdivide will produce a non-regular mesh. Quote Link to comment Share on other sites More sharing options...
