cspears2002 Posted June 1, 2009 Share Posted June 1, 2009 I'm working through the Houdini L-Systems Volume 1 tutorials from cmivfx. The instructor created a l-system and then a spare parameter that the l-system referenced with a ch() expression in the rules. This allowed him to adjust the length of the l-system on the fly. He would adjust the spare parameter, and the l-system's length would change in real time on the screen. I created a similar system, but I can't adjust the length on the fly. I have to set my generations parameter to 0 and then to new setting before the spare parameter can take affect. What am I doing wrong? Is this caused by a difference between Houdini 8 and Houdini 10? chris_lesson2_v02.hipnc Quote Link to comment Share on other sites More sharing options...
sparkChan Posted December 7, 2009 Share Posted December 7, 2009 (edited) I'm working through the Houdini L-Systems Volume 1 tutorials from cmivfx. The instructor created a l-system and then a spare parameter that the l-system referenced with a ch() expression in the rules. This allowed him to adjust the length of the l-system on the fly. He would adjust the spare parameter, and the l-system's length would change in real time on the screen. I created a similar system, but I can't adjust the length on the fly. I have to set my generations parameter to 0 and then to new setting before the spare parameter can take affect. What am I doing wrong? Is this caused by a difference between Houdini 8 and Houdini 10? hi, I have got the same problem when I watched the Houdini L-systems Volume 1. I didn't know why on that time. today I see your sence, although I don't know why, I solve the problem through creating a variable under values tap and referencing the spare channel. Note: the vairable name is what you want to name. Edited December 7, 2009 by sparkChan Quote Link to comment Share on other sites More sharing options...
sparkChan Posted December 7, 2009 Share Posted December 7, 2009 I'm working through the Houdini L-Systems Volume 1 tutorials from cmivfx. The instructor created a l-system and then a spare parameter that the l-system referenced with a ch() expression in the rules. This allowed him to adjust the length of the l-system on the fly. He would adjust the spare parameter, and the l-system's length would change in real time on the screen. I created a similar system, but I can't adjust the length on the fly. I have to set my generations parameter to 0 and then to new setting before the spare parameter can take affect. What am I doing wrong? Is this caused by a difference between Houdini 8 and Houdini 10? chris_lesson2_v02_modify.hipnc Quote Link to comment Share on other sites More sharing options...
