whether there is point on primitive?
atap3d
Hi. I have a lot of primitives and one point. I want to make following actions with each primitive: if point is not on primitive, it's necessary to remove this primitive. How to know, whether there is point on primitive?
check out the pointdist() expression. You feed it a point and a surface and it will tell you the closest prim on the surface to that point. Ive attacted a simple example.
pointDistEx.hip
Edited by SpencerL
Good example. Thank you very much. The solution true not up to the end. If point is not on one of primitives, your example leave nearest to point primitive. It should not be. If point is not on one of primitives, all primitives should be removed.
