slade Posted May 15, 2003 Share Posted May 15, 2003 Hi everyone, I am a relatively new comer to houdini and this is my first time posting in the forum, This may sound like a very stupid question, but can someone give me a little direction on how to start writing shaders ? Also how do you install a shader (for a lack of a better word) after you have finish writing one with a text editor such as vi or emac ? Thank you Bjorn Quote Link to comment Share on other sites More sharing options...
puma.snyder Posted May 15, 2003 Share Posted May 15, 2003 this is from an old post from wolfwood Or you could be cool and skip the editor and vcc and just use Houdini's Operator Type Manager. File > New Operator Type Fill out the options and select what context the vex operator is. In this case Surface shader. Click accept, then go to Vex Code Tab and type in your code there. Click accept when your done and viola, you have a new shader in SHOPs. jim. Quote Link to comment Share on other sites More sharing options...
slade Posted May 16, 2003 Author Share Posted May 16, 2003 Thanks jim, it worked like a charm. is there a way to compile your shaders inside of the textport ? Quote Link to comment Share on other sites More sharing options...
Wolfwood Posted May 16, 2003 Share Posted May 16, 2003 Glad I could help Thanks puma.snyder. jim. Quote Link to comment Share on other sites More sharing options...
anakin78z Posted May 16, 2003 Share Posted May 16, 2003 as far as learning how to write shaders, Jason wrote an excellent tutorial, which you can find on odforce (http://odforce.net/tips/shaderwriting1.php) Cheers, Jens Quote Link to comment Share on other sites More sharing options...
puma.snyder Posted May 16, 2003 Share Posted May 16, 2003 Glad U could help Thanks Jim Quote Link to comment Share on other sites More sharing options...
old school Posted May 17, 2003 Share Posted May 17, 2003 The best way to learn to write shaders is to use VOPs IMHO. The only problem is that there aren't too many tutorials that expound the principals of, say, the Advanced Renderman Guide for VOPs. Most of the examples in that particular book deal with anti-aliasing issues all over. A shader writer's worst hell sometimes. It is great to learn to write shaders but it is a pretty hard curve if you have never scripted or know little about what happens under the hood in a 3D app. VOPs almost eliminates this part of the equation. You just have to know what a string, int, float, vector, vector4 and bool are and that you can only wire two attributes that are the same. Each VOP encapsulates a particular function, set of functions to perform a task or an entire shader in a node. This corresponds to low level VOPs, mid level VOPs and high level VOPs that are all inter-mingled leaving a few landmines for novice users but you quickly learn which ones you are comfortable with. The greatest hurdle for a shader writer is anti-aliasing the shader. With VOPs, all the default noises and patterns are anti-aliased using acceptable methods. Procedural shaders rock in VEX (and PRMAN). The real great part for novices is that you can build the VOP network then inspect the code. It should look very close to the examples in, say the Advanced Renderman Guide. The code generated by VOPs is so clean. This part still impresses me. A good site to visit is Rick May's prman notes: http://www.accad.ohio-state.edu/~smay/RManNotes/ The layered approach to shader development is an industry standard way of developing shaders. Complexity without getting too complex in the shader code. Block out the parts then color mix the lot based on procedural patterns, texture maps or inhereted geometry attributes. -jeff Quote Link to comment Share on other sites More sharing options...
old school Posted May 17, 2003 Share Posted May 17, 2003 is there a way to compile your shaders inside of the textport ? [\QUOTE] Nope. Has to be command line vcc or use the new custom operator - optype mechanism which is more stream-lined. All houdini standard shaders have been converted to OPtypes in Houdini 6. Quote Link to comment Share on other sites More sharing options...
slade Posted May 19, 2003 Author Share Posted May 19, 2003 Thank you everyone for your help. I really appreciate it Bjorn Quote Link to comment Share on other sites More sharing options...
Xiangbuilder Posted June 18, 2003 Share Posted June 18, 2003 Many information is at shader.fmk.pdf. Quote Link to comment Share on other sites More sharing options...
