Bake That Occlusion ! shader
rob
Hi guys ,
Im in the process of building a baking tool for occlusion. I wanted to bend the shipping occlusion vop to my will :) . Of course when baking out a UV set you need to make sure face forward is turned off . My inner code is somewhat of a hack
vector $myP = $isconnected_P  ? $P: P;
vector $myN = $isconnected_N  ? $N : normalize(frontface(N, I));
if($facefwd) $myN = vop_frontface($myN);
$occlusion = occlusion($myP, $myN, "bias", $bias,
		"maxdist", $maxdist, "samples", $samples,
		"scope", $scope, "categories", $categories,
		"environment", $envmap, "envobject", $envobj,
		"envtint", $envtint, "background", $bgcolor , "angle" , radians($coneAngle), "filter " , "point");
I just wondered if this approach to hacking the vop code looks good or is my code causing issues with longer rendertimes
I've mostly got the occlusion baking tool working fine , but seems to take an age to run the render from the execute to finished frame
Render Time: 7.987u 0.358s 54.70r
Memory: 174.78 MB of 192.69 MB arena size. VM Size: 518.44 M
Thoughts ?
Edited by rob
Not sure what inputs are going to the inline vop, but why the frontface() calls?
Also, unless you have a reason not to, I'd look at the second version of occlusion() which returns a float.
cheers,
Michael
