Magnus Pettersson Posted July 2, 2009 Share Posted July 2, 2009 I swear i seen some discussion of this somewhere on this forum before but i cant find it again! I have a file node thats reading a bgeo sequence cache (orginally a imported geo from fbx) and i need the mesh animation in subframes also for some effects im doing, how do i do this? Quote Link to comment Share on other sites More sharing options...
Netvudu Posted July 2, 2009 Share Posted July 2, 2009 Timeblend SOP is your babe Quote Link to comment Share on other sites More sharing options...
Magnus Pettersson Posted July 2, 2009 Author Share Posted July 2, 2009 Ohh thanks a bunch, works great! some solutions is too easy to see, like searching for something but you actually hold it in your hand ;P Quote Link to comment Share on other sites More sharing options...
Magnus Pettersson Posted July 2, 2009 Author Share Posted July 2, 2009 (edited) ok i got another problem out of this.. im using a ray SOP and then chops to keep a surface deformed (chops: geometry -> trim -> envelope ->out) but i dont get the chops deformations on a subframe level it only updates on integer frames so i must have missed something here, its my first time "choping" *EDIT* .. increasing the sample rate in the "channel" tab of the geomtry chop seems to do the trick.. I tried to change it from 25 to 48 and nothing happened and then now an hour later i tested again and tried with 50, woila it worked Edited July 2, 2009 by Magnus Pettersson Quote Link to comment Share on other sites More sharing options...
