blackchicken Posted July 6, 2009 Share Posted July 6, 2009 Hello i have some little questions about grouping. 1, I use VORONOI FRACTURE tool to shutter a lot of differents 3d texts. I have forexample 3 different texts and I need merge it together like one object. But, if groups has same names they merge primitives together, and nuber of groups stay same. I need something which automaticaly rename groups. So object 01 has peace1-50 other same names, so i need after merge that second object will continue peace_51 Same problem is when I use duplicate 5 times in say X, all groups has same names and primitives is merged. So number of groups is same but every group grow X num copys... I need same names becouse I then use coloring peaces based on attrib transfer to switching then into dynamic RBD. Or I must rename groups in sop group node? IF yes, is there some easy expression? 2, Another little thing is, how I could easily offset bgeo cache, It is possible write something into path of reading cache? Sorry for stupid questions but I still have lot of things to learn about houdini thanks a lot all of you....BC... Quote Link to comment Share on other sites More sharing options...
michael Posted July 6, 2009 Share Posted July 6, 2009 2 - try the timeWarp SOP 1 - if you just need groups at the end of your merge, before you merge delete all the groups then use the connectivity and partition SOPs Quote Link to comment Share on other sites More sharing options...
