blue_riviera Posted July 13, 2009 Share Posted July 13, 2009 Hi, First, sorry for these very basic questions but (believe it or not) i looked for the answers in the forums first, but not found any (perhaps these are one of those questions with the answers _so_ obvious... ). I come from Maya, and although I appreciate Houdini's viewport-related features, I'm still looking for some features I couldn't easily replicate. How can I... - do "isolate selection", where I select a single (or a few) /obj object, and Houdini would (temporarily) hide all the other objects. - move multiple objects with the transform handle/manipulator? - get some stats about the geometry in the viewport (no. of polys, etc.) similar to Maya HUD (should work for multiple objects, so pressing MMB on a SOP is not the same) - snapping: how can I snap along a single axis? (in Maya: if you hold on to a single axis of the handle/manip with snapping enabled, it will move and snap along that axis only) Snapping in general feels a bit more 'uncomfortable' compared to Maya, I usually fall back to the Orientation Picking function (which beats M's most snapping tools, hands down -- the Construction Plane rocks! ). imre Quote Link to comment Share on other sites More sharing options...
edward Posted July 14, 2009 Share Posted July 14, 2009 1. Select your objects using the selection tool, hit ctrl+i to toggle the selection. Click on the display flag of one of the selected nodes in the network view 2. Select your objects using the selection tool, hit t Quote Link to comment Share on other sites More sharing options...
blue_riviera Posted July 14, 2009 Author Share Posted July 14, 2009 1. Select your objects using the selection tool, hit ctrl+i to toggle the selection. Click on the display flag of one of the selected nodes in the network view2. Select your objects using the selection tool, hit t hey, thanks. catched your drift... even extended it a bit: 1. to properly emulate maya's 'isolate select', one can first create a new take (with 'auto take' on), select the object(s) to isolate, hide the rest, and store it in the take. 2. it's good to know that the e, r, t tools work for multiple objects (i always tried the 'default handle' by pressing Enter). Quote Link to comment Share on other sites More sharing options...
