Simple constrain bone position question
Macha
maybe if you describe your problem a bit more
because this is pretty straightforward in houdini with any of the techniques you described that it is difficult to imagine what your problem can be
but maybe you are refering to the thing that if you parent root of the second bone chain to the last bone of the first and zero out its translates
it will jump to the root of the last bone not at the tip
you just need to offset the tz by -length of the last bone
or put a little expression to there like to do it automatically for you
oh, now i see you want to constrain the position only
the image wasn't moving in thumbnail :)
parent null to the tip of your first chain
append blend object and turn off RX,RY,RZ,SX,SY,SZ buttons on it
parent second chain to this blend object
Edited by anim
