JCB Posted July 17, 2009 Share Posted July 17, 2009 (edited) Hi, is it just impossible to compile Hot for WIN64? Edited July 17, 2009 by JCB Quote Link to comment Share on other sites More sharing options...
eloop Posted July 21, 2009 Share Posted July 21, 2009 (edited) It's relatively easy to compile once you have a functioning HDK development environment, however there is a bug somewhere which is corrupting the array values and I doesn't use windows any more. There is a good chance the bug is in one of the 3rd party extensions since the same code works ok under OSX (64 bit) and 64 bit linux (except maybe opensuse), it could also be a difference between VC and g++. The 3rd party extensions have both had updates since the last time I used windows so it would be worth trying again with the latest CVS version of blitz++ and the latest FFTW. -Drew Hi, is it just impossible to compile Hot for WIN64? Edited July 21, 2009 by eloop Quote Link to comment Share on other sites More sharing options...
eloop Posted August 26, 2009 Share Posted August 26, 2009 See this thread. It's relatively easy to compile once you have a functioning HDK development environment, however there is a bug somewhere which is corrupting the array values and I doesn't use windows any more. There is a good chance the bug is in one of the 3rd party extensions since the same code works ok under OSX (64 bit) and 64 bit linux (except maybe opensuse), it could also be a difference between VC and g++. The 3rd party extensions have both had updates since the last time I used windows so it would be worth trying again with the latest CVS version of blitz++ and the latest FFTW. -Drew Quote Link to comment Share on other sites More sharing options...
