hcustom error with SIM_SolverBullet
I am trying to compile the SIM_SolverBullet dll with hcustom, but I get the following error:
Creating library SIM_SolverBullet.lib and object SIM_SolverBullet.exp
SIM_SolverBullet.o : error LNK2019: unresolved external symbol "__declspec(dllim
port) public: float __thiscall SIM_BulletData::getCollisionMargin(void)const " (
__imp_?getCollisionMargin@SIM_BulletData@@QBEMXZ) referenced in function "protec
ted: virtual class std::_Tree<class std::_Tmap_traits<int,struct bulletBodystr,s
truct std::less<int>,class std::allocator<struct std::pair<int const ,struct bul
letBodystr> >,0> >::iterator __thiscall SIM_SolverBullet::addBulletBody(class SI
M_Object *)"
It created the .o and .lib files, but somewhere it's adding a __declspec(dllimport) call to the .o file that apparently I do not want. I compiled Bullet with Visual Studio 8 and hcustom is pointing to all the proper libraries. Any ideas where the problem might lie?
Thanks!
Looks like in SIM_API.h (within the Houdini toolkit), I had to comment out the __declspec lines, since hcustom did not seem to like them.
#if defined(WIN32) && !defined(MAKING_STATIC)
#ifdef EXPORT_SIM
#define SIM_API //__declspec(dllexport)
#else
#define SIM_API //__declspec(dllimport)
#endif
Now it compiles the dll.
Well done on solving the problem. I wonder why this is a problem?
#ifdef EXPORT_SIM
#else
#endif
Classes within external HDK libraries shouldn't have the *_API macro applied to them. This macro is only for internal Houdini libraries. ie, the correct code is:
class SIM_SolverBullet : public ...
   (and not)
class SIM_API SIM_SolverBullet : public ...
You should revert the SIM_API.h changes after the above change.
