bhaveshpandey Posted July 28, 2009 Share Posted July 28, 2009 (edited) I'm trying to setup a CHOP network which should control the position of every point on a Geometry. specifically I want a channel for each tx ty tz of these points.. so I put down a geometry chop and referenced it to the correct SOP, set the method to Animated, and scoped P attribute. the issue is when I export these after doing some math, adding noise and filters they all still move together as if they are connected. I checked the channels..and what I see is Points which are on the same row for eg..9,19,29,39...99 have the same channel for Tx.. thats why they look connected while being transformed. so I tried to randomise it by adding a Sort SOP to the grid..but still the movement remains the same.. I middle clicked on the Export chop an saw only 1st three channels were being exported back.. (this probably is the reason for their movement??) but again the shape of each channel curve for x, y and z is same.. what can i do to change channel curves for tx,ty,tz of each and every point..?? can anyone suggest any corrections or tell me where I'm going wrong? (basically i want every point to have a path driven by channels in CHOPs) I have recently started dabbling with CHOPs and dont have much knowledge. here's the hip file Thanks CHOPs_test1.hip Edited July 28, 2009 by bhaveshpandey Quote Link to comment Share on other sites More sharing options...
malexander Posted July 28, 2009 Share Posted July 28, 2009 You have the right idea, but instead of using an Export/Transform, use a Channel SOP. It reads the data back from CHOPs back into geometry. I've modified your hip file with this, hopefully it's what you're looking for. There was no need for the move attribute, export CHOP or Transform in this case, so I've removed them from the network. CHOPs_test2.hip Quote Link to comment Share on other sites More sharing options...
bhaveshpandey Posted July 28, 2009 Author Share Posted July 28, 2009 (edited) hey thanks a lot malexander..thats what I wanted However I did also try with Channel SOP but I put in the wrong attribute there.. I also got some similar results (a bit) by using Copy Stamping along with channel sop..(I created 3 Translation Attribs and CHOPed them and then used them in place of P attrib..coz I could not figure out where I was going wrong....pretty stupid though..I had to create same attribs) but that was a Desperate man's measure....haha Edited July 28, 2009 by bhaveshpandey Quote Link to comment Share on other sites More sharing options...
