MENOZ Posted August 1, 2009 Share Posted August 1, 2009 (edited) hello. in the RBD glue object when I try to write the volume collisino geometry to disk, when I set the file mode to "read" I see that the volume geometry is read back only for one glue piece.. certainly the others volume object aren't in the right place. It i set file mode to "no operation" the volume is generated correctly and the simulation it's ok, but if I want to write the geometry to disk to avoid to recalculate, it seems that it writes (or maybe read) wrong, and the sim goes bad. I just want to know if you have this problem too.. maybe it's a bug? EDIT: ok, solved after 2 second i wrote this post you just have to write a geometry for each object. with this expression I solved. $HIP/volumeobject_$OBJ Edited August 1, 2009 by MENOZ Quote Link to comment Share on other sites More sharing options...
bunker Posted August 2, 2009 Share Posted August 2, 2009 It was a bug that I reported 3 weeks ago. It has been fixed the same day, and it's available in the latest build of H10. Cheers, Julien Quote Link to comment Share on other sites More sharing options...
MENOZ Posted August 2, 2009 Author Share Posted August 2, 2009 It was a bug that I reported 3 weeks ago. It has been fixed the same day, and it's available in the latest build of H10. Cheers, Julien I have the lastest build 10.0.355 and I encountered this problem. the solution I found is to write a file for each object. Does it should work only with a single file? Quote Link to comment Share on other sites More sharing options...
bunker Posted August 2, 2009 Share Posted August 2, 2009 (edited) well, not sure anymore. I had a reply from sidefx saying the bug was fixed in the latest build ... I'll use the $OBJ anyway ... Still, I don't see the point of writing separate files for objects that have all the exact same "Ray intersect" values. I have the lastest build 10.0.355 and I encountered this problem. the solution I found is to write a file for each object. Does it should work only with a single file? Edited August 2, 2009 by bunker Quote Link to comment Share on other sites More sharing options...
