Compiling HOT on win 32-bit Vc8
ihab
I'm trying to compile HOT for windows 32-bit vc8. The cygwin shell spits the info shown in the image below but, a "Houdini 10.0" folder gets created in my home directory with an empty dso folder. According to shell there should be 3 dll files in that dso folder but that's not what happens. Does anyone know what would be the cause of this problem?
thanks
%5Battachment=7580:HOT.jpg%5D
Edited by ihab
thanks
Anyone ??! I know that HOT seems to be a hot topic right now on the forum but, i thought i'd open a new thread just to make things cleaner.
thanks in advance
Hi Ihab,
Can you first verify that you can compile standard HDK examples successfully, eg SOP_Star.C ?
-Drew
thanks in advance
Hi Ihab,
-Drew
Hi Drew,
thanks for creating such a great tool! I tried using hcustom to compile SOP_Star.C and the weird thing is that no errors are reported and the consol says that it created SOP_Star.dll at the $HOME/dso but still the folder is empty!! Pretty weird ??!?!
Thanks
You mean $HOME/houdini10.0/dso ?
Perhaps you need to see HDKFrequentlyAskedQuestions.
-Drew
Hi Drew,
Thanks
-Drew
Thanks for the pointer .. turns out the PATH env variable was missing a few folders in the VS installation folder. OK so now i can compile the sample SOP_Star.C and the dll is created in the $HOME/Houdini10.0/dso
However when i try to run the compile_win32.sh i get the following error and only the cleave dll is created ..
See this post
This will be fixed in the next release.
-Drew
Alright !! it worked after i commented the #define BZ_THREADSAFE in the ocean.h file. Thank you very much!
ok the dll is created but it doesn't load into houdini. I get the following error for both the ocean sop and the ocean vex Dso
strange because the cleave sop seams to work fine.
Edited by ihab
  • 2 weeks later...
